- fj12ryderExplorer IIII use an aluminum plate that has slots to go over the D-rings in the floor. The chock mounts on the plate and the motorcycle tie downs keep everything in place. And it takes only seconds to totally remove everything.
- joebedfordNomad IIII did. Two of the four bolts of the baseplate run through a steel cross-member. I only had to lower a corner of the coroplast to do it. Top part comes off easily when parked for a while.
Many people will tell you to spend $$$ to get a chock that doesn't need bolts. My $39.95 chock from HF works just fine for both mine and DW's Ultras.
About Fifth Wheel Group
