riltri
Jun 27, 2022Explorer
Thanks for the suggestions and even the criticism....I'm married, I can handle it!!
Backing is not an option due to other obstacles.
This is a private road. Not certain how the other 8 residents would feel about having their only egress blocked for half of a day eventhough the end results would be an improvement for all. It is a poor rural area, so getting help on the cost is not likely. I checked with a grading company. They said it is not a very long process to get county approval. But said $4-8K...he would need to look at it.
I think that pulling partially in then backing a couple of times might cut the turn radius down enough.
The steel idea is a good one!! I was a GC for many years and have seen properly supported steel used often for heavy construction equipment. It is often used in road construction with 18 wheelers running over it. Only issue is the weight and putting it in place.
Thanks again!
Thanks again!
About Fifth Wheel Group
