I have 1 friend with timbrens and his truck rides worse than a grain wagon. I've read that timbrens are supposed to allow about 1" travel before they hit. That means they would be hitting regularly on the roads around my side of the valley, even empty. Bags are adjustable and you can keep the back end at empty height, which is what I do, because I built my hauler bed low and close to the tires to give me plenty of bed clearance. You can also load closer to your tire and axle capacities or at least up to your payload w/o the truck squashing down so low, if that's what you'd like.
You can also do more with bags to tune out rough roads. Craig
