TenOC's avatar
TenOC
Nomad
Sep 18, 2023
Tips on how to hook up at an extreme angle?
We have a 2014 3100RL Montana with Mor/ride RPB72-1116 king pin with a Demco Autoslide 18K 5th wheel hitch.
Last campsite we had to unhook at an 25 to 35 degree angle – the first time for us. When we tried to re-hook we had difficulty connecting the hitch. Any suggestions or tips on how to hook up at an extreme angle?
  • Campinfan wrote:
    I have a Demco but there is no locking plate, it has the silver guide rails on the hitch. I have pulled them off or backed them all the way off....was pretty easy.....hooked up and then pulled out. If I had them off. I stopped, put them on and rehitched. Only took a few minutes. Without the rails in place, the hitch still works, it just does not "autoslide". If I had the rails backed off, I just slid them over once the trailer was straight and then tightened them.
    My hitch is a few years old now so the design might be a bit different from the new ones.
    Mine is the same as this ^^. I would do exactly the same given the circumstances. Just a few bolts to loosen off/remove and the hitch acts like a regular hitch and doesn't slide.
    The only alternative to this is to have a friendly neighbor hitch up to your trailer and pull to a spot where you can hitch up straight.
  • I have a Pullrite 24K Superglide hitch, the owners manual says the maximum angle of the trailer to the truck (being parallel to each other) is 10 degrees either way
  • I have a Demco but there is no locking plate, it has the silver guide rails on the hitch. I have pulled them off or backed them all the way off....was pretty easy.....hooked up and then pulled out. If I had them off. I stopped, put them on and rehitched. Only took a few minutes. Without the rails in place, the hitch still works, it just does not "autoslide". If I had the rails backed off, I just slid them over once the trailer was straight and then tightened them.
  • TenOC wrote:
    CarnationSailor wrote:
    s.
    You could remove the locking plate from your pin box,.
    To remove the locking plate is a 1/2 to 3/4 hour job.
    Maybe that's another reason why removing and re-installing it isn't a viable solution.
  • CarnationSailor wrote:
    s.
  • Not knowing 5th wheels is the locking plate necessary to move the trailer? Can you hitch up without it and move the trailer to level ground and stop and re-hitch? Yes it's a bunch of extra work. But desperate times call for desperate measures.
  • I have the same Demco hitch. Knowing that it will be extremely hard to unhitch/hitch up at an angle greated than 5 degrees, I make sure I never have to do that. This includes not reserving curved pull-thru's.
    You could remove the locking plate from your pin box, hitch up, and then TRY to re-install the locking plate; however, I expect it would be very difficut or impossible to re-install the locking plate.
    I wish I could be of more help.
