laknox wrote:
time2roll wrote:
I call that spring done. I recommend a higher rated spring with this issue. I moved from 1750 to 2250 and it has never ridden better.
x2! Replace all 4 packs and call it good. They're really not that expensive. I also agree with going up in capacity. If you're into the trailer for the long haul, add shocks at the same, time, too. Check out the Joyrider shock kit.
Lyle
Right now I am trying to see if it's still under warranty and I have looked at higher capacity they are 500 lbs axles. How hard are they to do it yourself?
