Colo_Native's avatar
Colo_Native
tire and axle problem
I have the Dexter e-z flex suspension and I have 1 tire that is rubbing the slide out frame bracket it appears that the shackle or the e-z flex is screwed up. HELP trying not to have to take it to the shop. You can see there is only 3/4" of clearance and hitting bumps make contact(see rub marks on tire)
  • time2roll wrote:
    Are you sure the springs and ride height is OK?
    Is the frame to tire clearance the same on both sides?
    Hangers and frame are square?
    everything looks ok, I haven't taken apart the shackles to see if the bushings are shot and I don't know if the spring is weaker than the other one. The slideout on the other side doesn't have that bracket
  • ScottG wrote:
    Hard to tell from pic but doesn't look like an axle problem but a frame clearance issue. What is that metal thing that's trying to poke your tire? Part of the frame?
    That is the slide out arm where you adjust it
  • Hard to tell from pic but doesn't look like an axle problem but a frame clearance issue. What is that metal thing that's trying to poke your tire? Part of the frame?
  • Are you sure the springs and ride height is OK?
  • Hard to make anything out with that photo, maybe back up a bit to get some reference. I can't really tell anything from the angle and detail, or lack of same.
