tomthyme
May 26, 2014Explorer
Tire lifespan
Hello Folks, First, thank you to all the veterans and families of veterans out there. On a run from Hot Springs today, we experienced our first blowout! We are grateful that no one was hurt. We ar...
CapriRacer wrote:tomthyme wrote:
Thanks for the assistance folks.
The best I can tell you on the weights is the rig runs around 15k (depending on how much water/wine we carry). I run 95-100 lbs of pressure in the tires, checking before every run, no matter how short or long.......
Good for checking the pressure before every run.
If I do the math, at 95 psi, the tire is rated for 3415# at 95 psi. Times 4 = 13,600#. If the weight on the tires is 15K, that would be 10% overloaded - on the average.
If 15K is the total weight of the trailer and we subtract 15% for the load on the tongue, then the tires are averaging 91% of the rated load - and that doesn't take into account side to side or front to rear variation. This sounds pretty marginal to me.
And that doesn't take into account the 15% reserve capacity I think all tires need to have.
Overall, I'd say you need to get the trailer weighed - tire by tire if possible.
