- centerlineExploreranti freezes of all types, that are readily available for all types of consumer use are designed to have a very low rate of evaporation, and to have a high degree of chemical stability so that the chemical composition of its ingredients remain fully in solution and not degrade for a long period (4-6 years and longer)
if it hasnt been diluted, its still doing its thing... - MFLNomad IIAs long as no water has entered the plumbing, you'll be fine, even if using cheap ethanol anti-freeze, that likely evaporated by now.
Jerry - JesLookinExplorerAs long as you got all the water out, no need to worry about the antifreeze.
- Second_ChanceExplorer IIRV antifreeze evaporates almost as quickly as water (and the ethylene glycol component evaporates more quickly). If I were you, I would add more to the drain traps to be safe.
Rob - agesilausExplorer III
ScottG wrote:
Absolutely. :)
Very likely - ScottGNomadAbsolutely. :)
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
