TS21sso
Oct 02, 2014Explorer
Tire Load Range
MY 5er has a GVRW of 10,800. I now have the OEM Akuret 235/80/16. Max load range is 3417. Maaxis of the same size is 3420. Discount tire recommends an LT and I am aware of the debates. The tire they r...
TS21sso wrote:
MY 5er has a GVRW of 10,800. I now have the OEM Akuret 235/80/16. Max load range is 3417. Maaxis of the same size is 3420. Discount tire recommends an LT and I am aware of the debates. The tire they recommend is the Michlien LTX M/S2 245/75/16. Same Diameter. Load Range 3042.
This is not about LT v/s ST., but, is this recommended tire, sufficient for my application.?3042 per tire gives a hypothetical GVRW of over 12,000 lbs. If this is not applicable, I will go with the Maaxis. Thanks
