smokindok's avatar
smokindok
Load Range D tire confusion
I have been reading the multitude of travel trailer tire threads and, embarrassingly, still have a question.
We have a Viking 17FQS (single axle) that came with Kenda LoadStar ST 205/75r14 Load Range D and the sticker on the trailer says inflate to 75psi. The tires are coming up on 4 years old and I thought it might be wise to replace before heading out on a few thousand mile trip next month. Having read the good reviews on the Goodyear Endurance and preferring to buy a USA made tire, I looked at my size options. Getting the Endurance in the original equipment size and LR D, the weight rating is 2040 lbs at 65psi, which is less than the original LoadStar at 2200 lbs at 75psi.
What I plan to do is move up to the Endurance 215/75r14 LR D, which will then match the original equipment tire’s 2200lb rating, but at the lower 65 psi. There is certainly plenty of room to accommodate the approximately 1/2” increase in diameter.
What has me puzzled is the rating on the original tire. Every ST205/75r14 Load Range D tire I looked at, other than the original equipment LoadStar, had the lower 2040 lb at 65 psi rating. There is only one tire from a single manufacturer that meets the original equipment specs.
It just seems strange to me. Am I missing something? Do I gain anything going with the Endurance in the slightly larger size? Or is there a down side going fro 75psi to 65 psi, even though both are rated at 2200 lbs?
Thanks!
John
