TS21sso
Oct 02, 2014Explorer
Tire Load Range
MY 5er has a GVRW of 10,800. I now have the OEM Akuret 235/80/16. Max load range is 3417. Maaxis of the same size is 3420. Discount tire recommends an LT and I am aware of the debates. The tire they r...
JIMNLIN wrote:mt1729 wrote:
Does anyone make a 15 inch Lt load range E tire?
No.
However many folks asking about a 15" E tire for their trailer may have a OEM ST205/75-15 C at 1820 lbs capacity. If thats the case your in luck.
Depending on room in the wheel well and proper wheel pressure/wheel width requirements the Goodyear Wrangler HT in a LT235/75-15 C (50 psi) at 1980 lb capacity. Most LT tire makers carry this size.
And a Wrangler HT in a LT215/75-15 D (65 psi) at 2090 lbs capacity.
Maxxis LT U-168 are a commercial grade tire with several 15" sizes with up to 2469 lbs and have became popular with all types of trailer owners.
Vanco 2 from Continental another popular tire for trailer users has several 15" sizes and load capacities up to 2469 lbs.
I see the Yokohama RY215 in a 700R 15 D at 2040 lbs capacity is popular on some of the other RV websites.
Do your home work on the numbers.
