I've read so many tire threads my head is spinning. I just put Goodyear G614 tires on my 39' 5 th wheel. They are a G rated tire with a load capacity of 3750 lb @ 110psi .. Should I be running at...
In order to get that ideal floor plan, side to side imbalance can be significant. My unit came with a sheet giving actual weights for each side and pin. Empty, the left side tires are carrying 600 lbs more than the right and because most of the inside storage is on the left side, that difference will be even greater when loaded.
