Tom_Barb
Nov 30, 2014Explorer
tinner12002 wrote:
I was curious to know if any of you have the TPMS sensors on their trailer tires and what you have your warnings set at.
The Newmar runs Michelins 22.5" X 10" that have a max pressure of 120 PSI. we set the warning at 115 PSI. the Toad has a max pressure of 80, we only run 45. so we set the pressure warning at 45.
You really must run the TPMS for the day you are traveling and find the optimum pressure that will not over heat the tires, yet not so high that any heat will over pressurize the ties.
WE found that 97 PSI cold will result in 105 PSI at running temps, it requires about 1 hour to come up to temp on a 80 degree day. The Toad never varies, set at 45 it stays at 45.
Run your system see what it does, experiment with the pressure.
About Fifth Wheel Group
19,033 PostsLatest Activity: Jan 25, 2026
