fly-boy
Dec 03, 2014Explorer
Macman83 wrote:
Wow. I will try to respond to the OP and answer his question.
I run the TST system, and set my G614 Goodyear tires at 80psi. On average, my tire temps will run 5 to 10 degrees above the outside temp, and the pressures will go up 8 to 12 psi after an hour of driving. I have also noticed that the temps are considerably lower than the temp of the rim and tire when taken with my IR temp gun. I have seen as high as 115 degrees, and 97psi when running on a hot day through the Oklahoma panhandle. This is all with a 2013 Voltage that weighs in at 16,800 lbs., with 3 axles.
Hope this helps.
80 psi is way too low on those tires- your tires are constructed and designed to run at a much higher cold psi. They will run cooler and last longer if you run them at 100-110. Low tire pressure causes a tire to run a lot hotter and just a few pounds makes a significant difference. On the G614 running them like you are you are going to start to have tread separation early and when they go it is ugly and expensive.
If your wheels are designed for a max psi of 80 you should switch tires and go with a the Michelin XPS. If your wheels can handle 110 psi you should pump those tires up for best results.
Plan to change the Goodyears out at four years- Have run them on several trailers and they are great for four years. At five they come apart regardless of how many or how few miles you have on them.
About Fifth Wheel Group
19,033 PostsLatest Activity: Jan 23, 2026
