fly-boy
Dec 05, 2014Explorer
debraindi wrote:
http://blog.goodsamcamping.com/2013/08/rv-tire-blowouts-increase-as-temperatures-rise/ I run 10 lbs below recommended.
Running your tires at max cold psi will keep the operating temps lower-
You have two things at work in a tire- pressure and heat. Running ten pounds lower than max will have a dramatic affect on the operating temp of the tire- especially when ambient air and road temps are high.
In my experience- Tires come apart for two reasons. They hit a road hazard that causes a catastrophic failure or they fail due to heat. A nail, while certainly a road hazard, does not cause the tire to fail. It is the loss of air and subsequent increase in temp that causes the big blowout.
Keep your tires at max cold psi and you will have fewer tire failures and your tires will last longer because they will run cooler.
About Fifth Wheel Group
19,033 PostsLatest Activity: Jan 24, 2026
