allcool
Dec 14, 2014Explorer
lincster wrote:jadatis wrote:
My conclusion is the lower speed that gives all tires more reserve before the tire damages , and thats almost always te case for LT tires, a speed of maximum 70m/h.
An ST tire is not that different then a LT but more often damage because of more deflection because of more load for the same pressure .
If you would give a LT tire the same pressure for the load as a ST of same sises and loadkind, it would also damage more often.
Wow, this is such wrong information I don't even know where to start.
LMAO...
Correct, not even going to try to sort that post out... All the real facts, would never change a thing in the way the ST crew thinks anyway, right...?
A poll with everyone that had blowouts with ST tires, and another poll of LT tire blowouts,(if you can find enough LT blowouts to make a valid pole..?) might be interesting to compare...
jmo
About Fifth Wheel Group
19,033 PostsLatest Activity: Jan 20, 2026
