NHIrish wrote:
You need to check your tire pressures and adjust accordingly as you move from cold temps to hot temps...or the other way around,
It depends on where they are set to start with, in relation to the max. stamped on the sidewall.
Going from cold to hot, if the pressure at your morning check doesn't go above the recommended max. you can leave them alone until your destination.
Going from hot to cold, add about 4 LBS before you start out but not going over the max. That should get you well into your trip before you have to worry about adding more.
