Made a list of pressure chanches for temperature for at sea level so 1013 mb pressure outside the tire wich is 14.692 psi.
Used the most used advice pressures and AT-pressures of most loadranges tires.
Only goes for when inside tire is completely dry so no water in it. this is never the case but cold measurements dont give that much extra rising or dropping of pressure by the water in it.
At boiling point of water the water inside tire can maximally rise the pressure by about 14.5 psi extra above what is calculated in the list. From 65 to 100 degr F the extra rising of pressure by the water is max 0.65 psi if there is enaugh liquid water in tire to go over to gas.
Then you see for instance that 1 psi /10 degr F only goes for about 38 psi filled at 65 degr F wich I stated as the advices been calculated for ( some say 68 or 70 ). For for instance 80 psi the rising is between 45 and 110 degr F about 1.8 psi/10degr F.
In Holland where I live we use , and . the other way around as in America. so , instead of . before the decimals.
