JIMNLIN
May 23, 2016Explorer III
Goodyear says quote;
Goodyear Tire and Rubber .... weighing RVs
Special Considerations
" Unless trying to resolve poor ride quality problems with an RV trailer, it is recommended that trailer tires be inflated to the pressure indicated on the sidewall of the tire. Trailer tires experience significant lateral (side-to-side) loads due to vehicle sway from uneven roads or passing vehicles. Using the inflation pressure engraved on the sidewall will provide optimum load carrying capacity and minimize heat build-up."
RVtiresafety.com says quote;
"The manufacturers do not take into consideration the side to side unbalance, as to do so would require them to provide larger (more expensive) tires. The other thing RV industry does not take into consideration is the forces to the tire structure due to running close axle spacing. Engineering analysis shows that when turning corners the forces trying to tear the tire apart can be over 20% higher in multi-axle applications than with tires at the corners of the vehicle.
The only options for the trailer owner are to up-size the tires (if there is room) or up-rate and increase inflation (if a higher Load Range tire and stronger wheels are available). Lacking the above being sure to run the tire at the inflation shown on the sidewall (i.e. max) will slightly decrease but not eliminate the overload forces."
rvsafety.com
Tire Load and Inflation Ratings
Note: Towable – Travel Trailer/ 5th Wheel owners Due to the severe use conditions experienced by tires when axles are very close together – tire industry experts recommend maximum (sidewall) inflation pressure for towable tires unless this causes a sever over-inflation situation (20psi+), often referred to as the ‘basketball effect’. If this is your situation allow a 10 – 15psi safety margin above the minimum required inflation pressure."
fifthwheelstreet.com
Step #5..
Selecting the Correct Tire Pressure for Your Trailer
We at Fifth Wheel St. no longer recommend adjusting trailer tire inflation pressure below the maximum load PSI rating molded on the sidewall (and only if the wheel/rim is appropriately rated) regardless of the measured scaled weight of individual tire or axle positions for all multi-axle trailers.
However, we do strongly recommend weighing individual trailer tire positions to ensure none of the axles or tire positions are overloaded. Reports have shown that trailers do not have equal weight across all tire positions. Some RV load configurations may reveal as much as 20% difference between the front and rear axle. This especially true for Toy Haulers. It is possible that mismanaged trailer load distribution will cause one end of an axle or a tire to be overloaded. It has been stated, but never confirmed by any RV Weighmaster, that there are many RVs traveling on the road with at least one tire or axle side overloaded. The only way to ensure tires and or axles are not overloaded is to weigh each tire position on your trailer. Unfortunately, attempting to obtain accurate individual tire position weight is practically impossible at all truck scales. View our list of recommend RV Weighmasters here.
- See more at: http://fifthwheelst.com/step5.html#sthash.FIAc3k0Z.dpuf
__________________________________________________________________
Never heard of derating a tire on a trailer with a minimum pressure from a tire chart till I came on a RV website. However some folks over tire their trailer above the 10-15 percent reserve capacity so common sense tells us at some point a 3750 lb rated tire on a axle with a 2800-3000 lb load 110 psi may be way too much tire and pressure for the job.
Like Michelin truck tire says ;
.. max tire performance and max reliability.. comes at max pressures.
I wouldn't reccomend anyone run a minimum pressure from a tire pressure chart for tire on a trailer. Tireman9 tire blog rvtiresafety.com on ply shear tells one story.
rvsafety.com
Step #5..
About Fifth Wheel Group
19,042 PostsLatest Activity: Aug 31, 2026
