Ever wonder why so many people think the tire manufacturers know all there is to be known about tire pressures?
Tire manufacturers build tires to specifications needed by vehicle manufacturers.
Vehicle manufacturers set recommended tire pressures for all of your vehicles. You know that the recommended air pressures for your tires is set by vehicle manufacturers and is the correct air pressure for your vehicle's tires under normal circumstances, right? Deviations will be found in the vehicle owner's manual.
FastEagle
