saltbayou wrote:
laknox,good suggestion,it says 80 for single or dually. Now thinking of going 70 all around. Seems like a good compromise. Started this thread because I'm getting ready to order a cat eye air kit. Thanks for all answers.
Those are max pressures for the tires!
Weigh your truck loaded and unloaded and use the charts.
Or do what I have done for thousands of miles and have proven even tread wear.
Run 70 front and you will wear the edges. Run 70 rear you will wear the centers. But if you rotate them at those pressures they will average out but you will bee lucky to get 40K from your tires.
