losmt21's avatar
losmt21
Tire Pressure Questions while towing 5th wheel
Everyone,
I will be purchasing my new 5th wheel this saturday. My 5th wheel will be GWVR 12,000. I currently ride with 65 psi while daily commute. I was thinking I would need to ride with 80 psi due to the weight. I have the ford 20 inchs rims and max air pressure stats 80psi. Would it be recommended to ride with max 80 psi>
2012 F250 Deisel Engine
Short Bed
  • What info does the label on the door have.
    Mine has 60 lbs front and 80 lbs rear for max load. Chevy - not a ford but should need similar pressure.
    My last truck had 80 lbs front and rear for max load.
    Found this info on the net:
    20" tires are size LT275/65R20. Here is the load inflation table for that size tire:
    PSI . max weight single
    35 . 2080
    40 . 2280
    45 . 2475
    50 . 2680
    55 . 2850
    60 . 3030
    65 . 3195
    70 . 3375
    75 . 3540
    80 . 3750
    "Single" means one tire on each end of the axle, not duals.
    So with 65 PSI in the rear tires, you could have up to 3195 pounds on each rear tire, or 6390 pounds on the rear axle, without overloading the tires. On the front axle - probably won't have over 5,000 pounds on the axle or 2,500 pounds on each front tire, so you need only 50 PSI in those front tires. Better to over-inflate than under inflate.
    My last CAT scale data (12,400 GVWR trailer)
    Steer Axle - 4900 lbs
    Drive Axle - 6060 lbs
    Trailer Axle - 9220 lbs
    Gross Weight - 20,180 lbs
  • Towing a 5th changes the weight on the front axle very little, so only the rear tires need to be adjusted for the increased load. I lower my rears to 44-46 when empty. Chris
  • agesilaus wrote:
    Usually 65 in front 80 in the back.
    BK
    Exactly the same that works for me
