partsman01's avatar
partsman01
Tire pressure sensor
So I do not own, never have owned one of those tire pressure sensors, but think maybe I should invest in one, here is one I found at Costco.ca for 76.99
Anyone with experience with this one?
The TireMinder® wireless tire pressure monitoring system provides peace of mind for RV, fifth-wheel, trailer or motor coach owners. Designed to continuously monitor tire pressure and temperature, it will warn of any abnormality. The four lightweight transmitters (with replaceable lithium batteries) simply screw into the valve stems. The TireMinder® monitors tires up to 145 psi.
Tire Pressure Monitoring System Features:
Application: RV and moderate industrial use
Pressure range: 0-145 psi
Monitors up to 22 wheels
Accurate to +/-2.7 %
User programmable warning levels (visual and audible)
Temperature alarm above 75°C (167°F)
Replaceable R1632 lithium batteries
7-year free battery exchange program
Kit includes:
Monitor
Heavy-duty multi-angle bracket
4 screw-on (TMT400C) transmitters 9 gm (0.32 oz.)
12/24 V car charger for monitor
TMB100-W booster
4 extra lithium batteries
4 anti-theft locks with hex wrench
Extra Transmitter Features:
2 per package
Accurate to +/-2.7%
Warranty:
1 year
Model: 10352426
  • Okay, thanks for the input.
    I will have to go in and see if they have it to look at.
  • doesn't show in the US costco site
    found it..
    the sensors are $35 each in the US so $70 for 2 (76.99 here)
    the base unit is $318 canadian.
    here is the tiretracker site.. $219 for the base, 4 tire kit
    http://www.technorv.com/TireTraker_Tire_Pressure_Monitor_p/tt400c-4.htm?gclid=COPUn42x5boCFWxo7Aod6yYAcw
  • grampscamper wrote:
    I believe the price shown is for the sensors only. I'm looking at buying this also from Costco.
    I would think that is correct. If you can get the complete system for $76.99 buy as many as you can cause that is a steal. Have had the system for 2 years. It is reliable and you do have to wake up the sensors when they have been idle.
  • I believe the price shown is for the sensors only. I'm looking at buying this also from Costco.
  • I use the TireMinder on my enclosed car hauler. I paid $199 for it 3 yrs ago. (4 sensors)
    I don't know about the TST system. My tireminder monitor seems 'slow' to me.
    if the trailer sits for a day, the sensors go to sleep. (save battery).
    but it takes 15 miles before they wake up again.
    I had one tire disintegrate at 16 miles from home, and the monitor went off as I was pulling off the road cause I saw it from the rearview mirror.
    tire minder and tire tracker are the same stuff with different labels.
    only thing I don't like is they want you to unplug the receiver after an 8 hour charge. but I don't always pull the trailer..
    I may go buy another one to get 4 more sensors!
