PokerCamper wrote:
I have Power King Towmax ST 225/75R15 D rateds (yep, Chinese bombs manufactured in late April of 2011) on the 29' 5'er we just bought. They're 2540# each, but my Cougar XLite has a GVW of just under 7,000 dry. The treads passed the penny test and have less than 8,000 miles on them, so I'm trying to get through this season and replace them with LTs next spring.
We're leaving for a 2 week vacation that will add about 1,200 miles round trip. Am I good running them right at the 65 psi (measured in the morning, of course) they're rated for or should I go a little lower since I'm towing light. I tow with tanks empty and though I haven't weighed it, I'd be surprised if we're over 8K pounds with payload.
IMO run the max psi on sidewall. My tires are the same size and the tires say 65psi and so does the sticker on the side of the 5'er. 9000lbs loaded, 6000 miles and all looks good.
2540x4=10160lbs. Minus the TW of 950lbs and you have 7050lbs on the tires. That's 3110lbs or a reserve of 777lbs for each tire. Well under the max load rating. The less weight on the tire the longer it will last. I'd be comfortable putting 1200 miles more on them.
