I was wondering what the consensus was for running max tire pressure according to the sidewall psi rating is? Our Toy Haulers are heavy but I am towing almost 2000lbs under the gross weight of the t...
The problem with running max tire pressure without having the max weight for that pressure is the tire is over inflated. This means the tire tread will not be flat on the pavement and could be a problem on wet pavement.
