1L243Explorer IIJun 26, 2015Tire PressureI was wondering what the consensus was for running max tire pressure according to the sidewall psi rating is? Our Toy Haulers are heavy but I am towing almost 2000lbs under the gross weight of the t...Show More
bigg-limoExplorerJun 30, 2015If you're 2k lbs under your gross,....run the max pressure. If you were several thousand under,...then it'd be a different story.
