smartyExplorer IIAug 27, 2018tire pressurejust had new G rated Sailun tires put on rig. These tires are rated at 110 psi Our rig weights around 19,000 lbs Am I okay to keep the psi at 90lbs or should I always keep them at 110 psi?Show More
Super_DaveExplorer IIAug 30, 2018I can tell that my rear axle on the trailer has a little more weight on it than the front. I could see running different tire pressures on each axle.
