smarty
Aug 27, 2018Explorer II
tire pressure
just had new G rated Sailun tires put on rig. These tires are rated at 110 psi Our rig weights around 19,000 lbs Am I okay to keep the psi at 90lbs or should I always keep them at 110 psi?
Super_Dave wrote:
I can tell that my rear axle on the trailer has a little more weight on it than the front. I could see running different tire pressures on each axle.
