smarty
Aug 27, 2018Explorer II
tire pressure
just had new G rated Sailun tires put on rig. These tires are rated at 110 psi Our rig weights around 19,000 lbs Am I okay to keep the psi at 90lbs or should I always keep them at 110 psi?
JIMNLIN wrote:And some of us are well aware of what we're doing, even if you don't like it. I run around 2500 lbs. on each wheel, and also have the Sailun LT S637 rated at about 3700 lbs. FWIW, I have had the Sailun tires for over 5 years and 20,000 miles and run them at 95psi. They show excellent wear, which is basically none BTW, and I intend to continue to do so despite all the horrible things that are forecast for my continued disregard for all the safety "warnings". Oh, and my fuel mileage hasn't changed from my initial setting of 110 psi, which resulted in a very harsh ride.
Some folks do silly things like mount a load G tire at 4080-4400 lbs on 5.2k/6k axles with 2500-2800 lb load per tire. Then derate them to 80-90 psi. Most RV folks can get by with it as they don't use a tire long enough to wear it out plus a commercial grade all steel carcass tire like the S637 can take abuse like that. One newby actually went with 17.5" load H S637 at 6006 lbs capacity per tire on his trailers tandem 6k axles with 2550 lb load per tire. Aired them to 80 psi and complained about them running hot and mpg drop for his 6.7 Ford truck.
