smarty
Aug 27, 2018Explorer II
tire pressure
just had new G rated Sailun tires put on rig. These tires are rated at 110 psi Our rig weights around 19,000 lbs Am I okay to keep the psi at 90lbs or should I always keep them at 110 psi?
fj12ryder wrote:wilber1 wrote:Actually yes they are recommended pressures. Per Goodyear's RV's Tire Care Guide: "Inflation pressure should be adjusted to handle the tire carrying the heaviest load, and all tires on the axle should be adjusted to this pressure."
Load inflation tables just tell you how much load a tire can carry at a certain pressure. They aren't recommended pressures.
