smarty
Aug 27, 2018Explorer II
tire pressure
just had new G rated Sailun tires put on rig. These tires are rated at 110 psi Our rig weights around 19,000 lbs Am I okay to keep the psi at 90lbs or should I always keep them at 110 psi?
It does make you wonder why they choose to post conflicting information. Since right here is the conflicting part: RV Tire and Care Guide
And, if lessening the air pressure is bad for the tires, why would any tire company give you the chart to set your pressure to the weight being carried by the tire? Or do you know some secret the tire people don't know? Do you suppose they purposely are tying to ruin your tires by giving false data?
