smarty
Aug 27, 2018Explorer II
tire pressure
just had new G rated Sailun tires put on rig. These tires are rated at 110 psi Our rig weights around 19,000 lbs Am I okay to keep the psi at 90lbs or should I always keep them at 110 psi?
Okay, let me get this straight: you, Tireman9, and CapriRacer say it's bad to run lower than max air pressure regardless of weight loadings.
