Rich_Mar
Sep 11, 2020Explorer
tire pressure
do you run the max pressure in your tires as written on the sidewall? I have the Endurance, and it states 80# psi. Seems to me you need to take the outside temperature into consideration. I an relu...
CapriRacer wrote:Disagree. I've seen tires burst while mounted as a spare and never been on the road. One was mounted on the rear of a trailer, under a vinyl cover, and it blew a hole in the cover. Saw another one burst that was mounted under the trailer as a spare. Cheap Chinese tires.
Just so everyone knows: The burst pressure of a tire is many times the max pressure. Unless a tire is on fire, there is no risk of the tire bursting on its own without it being damaged by some object - even in Death Valley!
