Rich_Mar
Sep 11, 2020Explorer
tire pressure
do you run the max pressure in your tires as written on the sidewall? I have the Endurance, and it states 80# psi. Seems to me you need to take the outside temperature into consideration. I an relu...
MFL wrote:CapriRacer wrote:
Just so everyone knows: The burst pressure of a tire is many times the max pressure. Unless a tire is on fire, there is no risk of the tire bursting on its own without it being damaged by some object - even in Death Valley!
Interesting...I know it would vary, all ST tires not being equal, in quality and design, but what would you consider a possible psi bursting point of the OPs GY Endurance E-rated tire, if air is continuously added? I know you can not give an exact psi, but maybe a range of psi guess?
Jerry
