Rich_Mar
Sep 11, 2020Explorer
tire pressure
do you run the max pressure in your tires as written on the sidewall? I have the Endurance, and it states 80# psi. Seems to me you need to take the outside temperature into consideration. I an relu...
MikeRP wrote:It's a triple axle toyhauler that came with "E" rated ST tires from the factory. They were the notorious "China bombs" and I had two blow out within 2 years. I wasn't about to go back with another set of ST tires, and LT tires would have been okay, but not great. So I went with the Sailun "G" rated tires. When I bought them, they were labeled "LT" tires, but stated on the sidewall: "For Trailer Use Only", and now they're labeled "ST" tires.fj12ryder wrote:TxGearhead wrote:Maybe if you're running ST tires, but I run my Sailun "G" rated tires at 95 psi rather than the 110 psi that is the max pressure. Makes for a much smoother ride. And with 2000-2500 lbs. per wheel I don't need to run the max pressure.
Always run trailer tires at max pressure no matter how many axles.
I was just wondering if you only have 2500 lbs per tire, why did the manufacturer put g rated tires on your rig? I agree you probably don’t need to run that weight at max pressure. I’m probably at 3000 lbs per tire loaded.
