do you run the max pressure in your tires as written on the sidewall? I have the Endurance, and it states 80# psi. Seems to me you need to take the outside temperature into consideration. I an relu...
I have run my trailers tires at max sidewall pressure for over 30 years with no blowouts or even a flat tire. If I were still towing today I would continue that practice. Most trailers are loading the tires to very near their maximum load and the tires need all the help they can get. I also upgraded my tires and rims from stock "C's" to "E's" as the tires wore or aged out. Barney
