Rich_MarExplorerSep 11, 2020tire pressuredo you run the max pressure in your tires as written on the sidewall? I have the Endurance, and it states 80# psi. Seems to me you need to take the outside temperature into consideration. I an relu...Show More
DogTrainerExplorerSep 15, 2020I just had the Goodyear Endurance installed 5 days ago. Goodyear recommended and told me to keep the tires AT 65lbs per tire unless I was at MAX LOAD.Do not run tires at MAX LOAD unless at full weight capacity
