Rich_Mar
Sep 11, 2020Explorer
tire pressure
do you run the max pressure in your tires as written on the sidewall? I have the Endurance, and it states 80# psi. Seems to me you need to take the outside temperature into consideration. I an relu...
DogTrainer wrote:Goodyear recommended it, or the guy at the tire shop?
I just had the Goodyear Endurance installed 5 days ago. Goodyear recommended and told me to keep the tires AT 65lbs per tire unless I was at MAX LOAD.
Do not run tires at MAX LOAD unless at full weight capacity
