do you run the max pressure in your tires as written on the sidewall? I have the Endurance, and it states 80# psi. Seems to me you need to take the outside temperature into consideration. I an relu...
Know your ACTUAL tire weights!!! Then use the weight/inflation chart for your RV tires. Now add 5psi to what the chart says. Per GY Tech when upsizing load range or wanting the best possible ride, tire wear and stopping power.
