Rich&Mar wrote:
do you run the max pressure in your tires as written on the sidewall? I have the Endurance, and it states 80# psi. Seems to me you need to take the outside temperature into consideration. I an reluctant to inflate to 80 psi and go on the road when it's 90% out. Then it becomes a guessing game, what psi at 90, at 75, at 45 degrees. 8200lb 5er. The sidewall does read, max pressure, so should you put less due to the temp? Or let the pressure go well over the 80 because of the heat?
Sometimes they write maximum cold pressure, and yes, as already written, pressure rising above yours 80 psi is included in the advice.
A few years ago I read from Capriracer or Tireman9,in a topic, that tires have teststandards, that they have to stand 2 to 3 times the referencepressure( what you think is the max pressure). For 80 psi this would mean ( sit down first) somewhere between 160 and 240 psi.
If you fill with 1.4 times reference ( 1.4 x 80= 112 psi) at freesing point 32 degr F. And incidentially temp in tire rises to boiling point212 degrF, the pressure will rise to a small 2x reference ( 2x 80 psi= 160 psi) , so still within the testing standards.
So dont worry about a the relatively small pressure rising you mention.
But not always maximum 80 psi is needed, for instance tandem-axle trailers can often do with much lower.
Let me calculate a safe pressure for you, with max reserve, but still no bumping.
