Eyetattoo
Aug 05, 2013Explorer
Tire pressure
Just curious of what tire pressures you all run when going to the dunes, specifically Pismo. I normally run roughly 20psi on the truck and roughly the same for the toy hauler.
N-Trouble wrote:That is the one of the downsides of Pismo, I stay as far away from the water as possible but still set surface rust. First thing I doe after a trip is wash both the TV and TH.
20PSI is good. THere are places I go where I don't air down, but Pismo is not one of them. If you wait til you get stuck chances are your going to need to get towed out there. As soon as I hit the beach, I air down and can go about anywhere. Keep your speed up, no sharp turns, and have your line figured out before you make a run for it. I also try to stay out of the sea water. It will rust the underside of your trailer in no time.
