Rvpapa
Jul 20, 2016Explorer
Posted: 07/20/16 01:46pm Link | Quote | Print | Notify Moderator
So, I'm digging through all the technical information on our RV and finally made it to the tire info.
Our RV has Towmaxx ST tires on it. Yes.. I know... Towmaxx means "replace immediately" in some circles.
Anyway.. here's where I'm confused. the tires are ST235/80R16-E's
According to the Towmaxx website, these tires are rated at 3520lbs @ 80psi when mounted single. Okay, cool. There are four tires on my particular RV, which means it has a total load capacity of 3520 X 4 = 14080lbs. But wait, the GVWR on this RV is 15,500lbs!
So, the tires being the lower number, does this mean that I can carry no MORE than 14080lbs hitched or do I need to account for hitch weight as well? This is 2580lbs. subtract that from the GVWR and you have 12,920lbs which would put me under the max rating for the tires.
This is where I need some help. am I calculating this right?
GVRW - hitch = sprung weight
Sprung weight / number of tires = Max weight per tire
I'm hoping this is right. I'm trying to figure required tire pressures (in case anyone is wondering why I'm doing this
Now I know - I KNOW - I need to go get weights done. I get it. I just don't happen to have a Cat scale at my desk and wouldn't you know it, I left my RV at home when I came to work this morning. So I'm using published, generic weights here - keep that in mind. However, if I'm doing the math right, then I can plug in my scale weights in when I get them this weekend.
Don't do it. Inflate to max sidewall pressure.
Art.
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
