prstlkExplorerApr 30, 2023Tire pressuresThis has probably been asked before but because we are leaving in the AM for the summer I need quick advise from the folks on here. We have a 2013 Ford F350 SRW 6.7L Diesel and a new to us 2016 Key...Show More
Cummins12V98Explorer IIIMay 01, 2023The tires does NOT say to run 80psi!!!!!!! It says for MAX load air to 80psi. Unless you are overloading your axles 65psi will be JUST FINE!!!Good call on the ENDURANCE!Weight your rig and use the weight/inflation chart then add 5psi to that number. PER GY Tech Support when going up in load range.
