prstlk
Apr 30, 2023Explorer
Tire pressures
This has probably been asked before but because we are leaving in the AM for the summer I need quick advise from the folks on here. We have a 2013 Ford F350 SRW 6.7L Diesel and a new to us 2016 Key...
We have a 2013 Ford F350 SRW 6.7L Diesel and a new to us 2016 Keystone Cougar 30' fifth wheel.
We just put on 4 new Goodyear Endurance tires on the 5th wheel. The tire says to run at 80psi and that is what the tire company put in them.
The label on the 5th wheel says to run 65psi in the tires.
Which should we follow? One of us says the label recommendation and the other says the tire recommendation.
What say you? Please advise!
Your rig is almost certainly placarded for D-range tires, which are 65 psi. Your new GYs are E-rated, which is why the sidewalls say 80 psi. Personally, I'd run the GYs at 70, since you're "over-tired" for the weight of your FW. Will ride a bit better and you'll have a bit more "footprint" on the road. Even then, if you check a load chart, you'll have more tire capacity than the D's at 65 psi.
Lyle
