prstlk
Apr 30, 2023Explorer
Tire pressures
This has probably been asked before but because we are leaving in the AM for the summer I need quick advise from the folks on here. We have a 2013 Ford F350 SRW 6.7L Diesel and a new to us 2016 Key...
We have a 2013 Ford F350 SRW 6.7L Diesel and a new to us 2016 Keystone Cougar 30' fifth wheel.
We just put on 4 new Goodyear Endurance tires on the 5th wheel. The tire says to run at 80psi and that is what the tire company put in them.
The label on the 5th wheel says to run 65psi in the tires.
Which should we follow? One of us says the label recommendation and the other says the tire recommendation.
What say you? Please advise!
Not to start an argument, but apparently the OP’s trailer was equipped with D rated tires and the load sticker shows proper pressure. Many ST tires do not have a web page showing pressure vs load. That’s the reason for using sidewall listed pressurization .
