Scott_M's avatar
Scott_M
Tire Problems and What to Upgrade To?
Last fall we took a trip to North Carolina, mostly on interstate to visit family. After returning from the 1500 mile trip, I noticed that the rear wheels had come into contact with the plastic fender trim and had also bottomed out in the wells. We travel with empty gray and black water tanks, ¼ full fresh tank. We almost always have less than 1100# of payload (3305 max capacity).
Thinking I had a bad spring, I replaced all springs and shackles with a slightly higher capacity spring and wet bushings. While replacing a tire, I cut my hand of the tire I was trying to mount. I looked at the tire thinking there was a nail or piece of glass stuck in it, but found a small section of steel belt sticking out of the tread. I looked closer and found a bubble in the tread as well. These are the original tires (3 years old and about 6K miles), Power King Tow Max STR’s (ST225/75R15, D Range). I knew that the tires were probably not the best, but I thought I should get at least 10K miles out of them. The GVWR on my fiver is 9950 with tandem 4400 axles and rims 15” x 6” (J).
Anyway, since I now have to replace the tires, I have been looking around the forums and internet. It seems like most people are opting for LT over ST tires. If I type in my tire size I get a lot of hits for the ST size, but very few for the LT size. Having read about a lot of D range tire failures I thought about upgrading to at least E range, but I have to check the rims for the maximum pressure/weight rating. I would hate to have to upgrade the rims as well, but I will if I have to. Anyone have any advice regarding the conversion from ST to LT? I cannot increase my tire size because the axles are already under the springs and I only have about 2” on average of well clearance.
