cummins2014
Apr 12, 2020Explorer
Cummins12V98 wrote:cummins2014 wrote:N-Trouble wrote:
Wont run anything but LTs. Bridgestone Duravis R250. I dont get caught up in all the capacity numbers like some of the propeller heads in here. Simply holding a good LT tire in one hand and a shitty ST in the other tells the story. No comparison...
Well sure you won't . Your toy hauler has a dry weight of 8755 Gross of 11,900, and a pin of 2035. Loaded to your max GVWR, and being conservative at 20% on the pin you are about 2380 per tire ???? Why not run LT's @ 3042 per tire.
There are some of us propeller heads running just a tad more then 2380 per tire. I am sure you don't get caught up in capacity numbers either at your weigh.
What are U talking ABOOT EH?????
I am "ONLY" 4,360# average per tire. More recently I have gained a few pounds and now running 4,495# per tire average.
You are getting darn close to those G114's weight rating of 4805, if thats what I assume you are running . Where do you go from there ??
About Fifth Wheel Group
