Carlos___Ranae's avatar
Jun 21, 2017
Tire separated from axle
While traveling on I-95 North near the border of Georgia and South Carolina a vehicle pulled next to me and yelled out that I had lost a tire. I pulled to the shoulder and the passenger side first wheel on the triple axle was gone. The rear panel of the camper was damaged and by the grace of God no other damage. The vehicle that stopped us had suffered damage to their rear passenger rear quarter and again the Lord blessed us, no injuries. The lady passenger said when she saw the tire bouncing towards them she thought it was going to go through the windshield. Insurances and warranty will take care of damages. Unknown caused for all bolts to failed. Internet is not good, may not be able respond to comments.
  • nayther wrote:
    discovery4us wrote:
    I have also seen lug nuts cross threaded and ran down with a air gun. Will eventually cause studs to snap and tire and rim to go for a joy ride.
    "always refreshing to see a tire shop use a torque wrench for final setting. Stretched lugs WILL fail."
    What is the proper torque on 16" aluminum toy hauler wheels?
    90-95 ft/lbs
    But check the wheel manufactures numbers directly.
  • All to sheer at the same time?
    I find that hard to believe.
    Something was probably already snapped/cracked and driver didn't know it.
    I always torque my own trailer wheels and when I get my vehicles done at Discount, I watch them do it and ask to see the torque wrench to verify the setting.
    I just had my wife's tires put on she called me a few days later histerical. Her rear wheel lost all but 2 lug nuts. She almost lost the rim on the hwy. I will never make the mistake of trusting anyone with my lugs unless I see it with my own eyes.
    it starts with one or two, additional stress on the remainder and poof, they snap.
    I've had sheared lugs on trucks and trailers when I had a hauling business. On the road sometimes 7 days a week for 11 years straight you see this often....on all types and sizes of trailers.
    Myself and my drivers have found a loose trailer wheel with any combination of one or two sheard lugs with the remaining nuts loose or maybe a wheel with one loose nut and the other lugs and nuts gone......and all the lugs sheared off and a missing tire/wheel assy. Generally if the wheel can be found it can tell the story of what did and didn't happen.
    These trucks and trailers tires/wheels/hubs were always pre trip inspected and checked any time the truck was shut down for fuel/rest/HOS/etc.
    90-95 ft/lbs
    http://www.countrytrailer.com/wndisplayItem.asp?number=25
    Depends on size of the studs too.
    I have to say my studs all seemed a bit soft or stretchy when setting the torque since it was new. When I changed to disk brakes the studs are very firm like a different steel was used.
    Also important to re-check the torque after running a hundred or so miles or after the first long day.
  • I lost a wheel on the front street side going down the highway. Rear axle, street side was loose and missing two lug nuts. Had new wheels and tires installed a month earlier.
    On the way home from the tire installer I stopped and checked the lugs at 10, 25, and 55 miles later when I was at the RV park I was staying at.
    Two months later I checked all the lugs because I would be leaving for a job in FL in a week. It turned into an ordeal finding hubs to fit the RV. Hubs were damaged on the street side from the sheared studs and wobble.
    24 hours later the Mobile Mechanic had us back on the road. Never figured out why the one side came loose and the other has been good since day one.
    I am so paranoid of loosing a wheel now I check the lugs before leaving, at 25 miles, 100 miles, and at each and every stop before proceeding. I know it is overkill but, I cannot get that nagging concern out of my mind.
