rhagfo
Mar 10, 2016Explorer III
smkettner wrote:
GY-LT says 3024. Could be a misprint.
GY-ST is 3420. So the LT is rated lower numerically on the sidewall.
http://www.goodyearrvtires.com/tire-selector.aspx
No reason for confusion.
Or are you trying to choose the absolute lowest rated tire for the scale weight of the axle?
Would you go lower rated on your truck based on scale weight?
Good luck with that.
Yes, size for size the LT is rated lower than an ST. That said, if the weight I am carrying on the LT doesn't exceed it capacity. I will take an LT rated tire any day of the week.
If NC Hauler is concerned, he can go to a "G" rated tire and rim. I just don't see that is is needed, I will be replacing my tires some time this year due to age, not failure.
About Fifth Wheel Group
19,040 PostsLatest Activity: Jul 08, 2013
