- NamMedevac_70Explorer IIFor many years in high heat of Texas, Nevada and western states summers I had excellent results with Maxxis ST and Goodyear tires on my 28 foot 4500lb TT that was always heavily loaded. No flats or blowouts and only one minor valve stem leek that was quickly fixed in small town of Salina UTAH. K&K auto and diesel was PDQ and friendly. Good folks. This was in 2012 I believe. Cheers to the die hards.
- HuntindogExplorer
savitri99 wrote:
I am in Phoenix AZ. They are calling for 118 here on Sun.I ran Michelin XPS RIBS for 15 trouble free years here. Not cheap, but you did not ask about the price. Smart. One blowout can cause enough damage to pay for a lot of tires. Not to mention a ruined trip. If you want more info, PM me.
I am looking for the best trailer tires I can find for hot weather
Any suggestions? - mosseaterExplorer III'm on my 3rd set of Maxxis and have no complaints
- JIMNLINExplorer III
Any suggestions?
Welcome to the forum.
RV trailers can come with 13" tires at 1300 lbs capacity or the big guys 17.5" at over 6000 lbs capacity.
You will get better selections if we knew your trailer OEM tire size and load ranges.
Trailers gvwr.....axle ratings is helpful. - MARKW8ExplorerWe have been towing in Texas. 105+ degrees. We've had no issues with our Goodyear tires on our trailer.I was concerned when I saw 111 degrees on the monitor, until I checked the outside temperature. It was 106.
Mark - Boon_DockerExplorer IIICarlisle, have been using them for years with no issues.
- Grit_dogTrailblazerWow, this topic has never come up before.
OP you can find more info than you want on this forum already.
But this will be a good place for the hard headed to congregate and claim you should get LT tires.
And PS, if you do want help and can’t search then at least provide some more info. You just asked who has the best French fries basically. - StirCrazyModerator
CapriRacer wrote:
Look for tires with a cap ply (or more than one!) Cap plies will be in the tire description on the sidewall - as in Tread: 2 plies Polyester, 2 steel and 2 nylon. The nylon = cap plies. Sometimes it is called polyamide.
I don't ever think I will buy a nylon capped tire again. My old types were 2+2+1 and they were the typical using polyester and nylon, the new tires I got are 2+2+2 but labeled all steel belted radial so no Polly or nylon belts. I was reading this has something to do with the side stresses put on a multi axel unit's tires when doing tight turns, but I can seem to find that article again. I had one blow out last summer and when I went to replace it this spring, I found two others that were rounded across the top of the tread so that indicates they were separating. 4 brand new tires this year with hopefully better construction. - MFLNomad II
Agree, the newer nylon capped ST tires will generally run cooler. Look for the higher speed rated brands. I recently installed another set of Provider STs, after running the same, for 8 previous years.
Heat is often due to sidewall flex, from lack of support, due to design, or under inflation.
Buy the proper ST tire for your load, and run them at max pressure indicated on the sidewall, for coolest running. While you can lower
ST tire pressure to match your exact wt, as scaled, to improve the ride, it will increase heat.
Jerry - CapriRacerExplorer IILook for tires with a cap ply (or more than one!) Cap plies will be in the tire description on the sidewall - as in Tread: 2 plies Polyester, 2 steel and 2 nylon. The nylon = cap plies. Sometimes it is called polyamide.
